My booster pump stopped working after a power failure. To isolate the failure, I tried to run it directly from a 115V socket, bypassing the pentair easytouch. I followed your YouTube vid.
How to: Wire Whisperflow & Similar Pumps for 115V https://www.youtube.com/watch?v=cAdQBjsSDhU
This is my Pentair LA01N booster pump:
When plugged in to my 115V wall socket, the breaker immediately trips. Here is the wiring panel of the pump, connected to 115V power:
If you look at the brown wire on terminal B, you can see that someone wrapped it with a white tag or piece of plastic. Has the brown wire been “converted” to a white wire? Could this indicate why the pump won’t run on 115V?
Do you see anything wrong with my wiring? Any suggestions as to why the pump doesn’t run?
Thanks for you help.
