which sta-rite pump parts to replace with new motor
hi- thanks for recommending the century ecm16squ variable speed motor to replace my sta-rite c48k2pa105 motor.  i can’t find the sta-rite model name on the pump but motor states it is mpra6e-147 so i think it is a dyba-glas model.  i have a couple of other questions and then will place my order"
1-which seal kit to use?
2-do i need to replace the impellar or diffuser?
3-the diffuser has about some locking teeth type washers that have corroded away and cannot find stainless steel type at any local hardware.  do you sell any (would need about 10).
4-do you carry a gasket sealer i can use for when i try to rebuild the motor/pump?
thanks so much for your help.  your site is really useful and would rather buy from y’all since you give such great advice !
  1. The tune up kit for the Dyna-Glas is GOKIT44.
  2. Most of the time the impeller and diffuser do not need to be replaced. You can open up the pump and inspect these parts for damage.
  3. We do sell the washers for the diffuser individually. The part number is 5056-23.
  4. I’m not exactly sure which product you are describing. Silicone lubricant comes with the tune-up kit. Let me know if you need something else.
