Motor model #177475 which is the effcent replacement and the regular replacement motor and what else should i get to replace motor and attach to existing pump
Hello Apexwf - The single speed standard efficiency option would be model B2848. The single speed energy efficient option would be model B2841.
The most energy efficient option would be the variable speed model ECM16SQU. The variable speed motor can save up to 80% on your energy consumption. The installation is very simple and it’s wired just like a single speed.
We would also recommend replacing the seals when you replace the motor. The tune-up kit for the Whisperflo is GOKIT32. Go with the GOKIT32SALT if you have salt water.
