Which gasket is correct? Pac Fab Pool AND Spa light bulb replacement
Hi guys, I’m having trouble finding exactly which gasket I need for both my Pool light & Spa light. I’d also like to replace the bulbs with whatever is the most reliable LED color bulb you guys recommend. Or if the color bulbs are crappy I could just do a white LED. I basically want whatever is most likely to last a long time so I don’t have to mess with this again for years…
Here’s the info from the labels on the lights (pics also attached):
Pool Light: Pac Fab Inc. Model 60-X11X, Housing 62-XXXX. 100W Max 12V R30 Bulb.
Spa Light: Pac Fab Inc. Model 64-311X, Housing 66-100X or 66-101X. 75W 12V MR-16 Bulb.
Would also love any tips to help ensure no leaks when I change out the bulb and reinstall the lights.
Thanks! -Baron
The pool lens gasket is part number 57-110-1272.
The LED color changing bulb would be part number LPL-P2-RGB-12.
The spa lens gasket is part number 57-110-1327.
Unfortunately, we do not currently carry an MR-16 LED bulb.
Thank you! Just ordered some parts.
We appreciate it. Have a great day!
