Sorry I could’t figure out how to rotate the image.
I’d like to replace this light as it was never working since I bought the home. I pulled it out to see if I can replace the bulb and obviously this is not a serviceable item. I have since put the non working light back in.
Does anybody know what replacement light can I use that would fit in my light niche, by looking at this label? I DO NOT want to use this expensive unserviceable type of light again. Can I use a Pentair standard halogen or incandescent type and be able to replace the bulb with an LED version.
Thanks from a Pool Newbie.
Good afternoon, so if you have a deep niche then you can use a Purecolors LED light model PL5832. However, you will need to confirm whether your niche was specific to your Colorlogic light being shallow or if it is a Hayward deep niche which are approximately 7-8 inches deep. If you have a Hayward deep niche then you can use the Universal Light Adapter ring in order to mount your Purecolors light to the pre-existing niche.
