WF-24
Hi - got a Pentair WF-24 which has stopped turning. The casing is hot but I’ll try replacing capacitor first.
If I have to replace the motor the spare part number is 011772. Motor casing says 1 HP and SF 1.25 HP.  Which motor would I need to order from you guys?
The replacement motor for your Pentair Whisperflo WF-24 is part number B2853. Click Here to View More Details on the B2853 Motor
If you live in California, you’ll have to go with a multi-speed motor. The variable-speed motor option is model ECM16SQU.
We recommend replacing the seals when you replace the motor. The standard seal kit is GOKIT32. The seal kit for salt water pools is GOKIT32SALT.
