water table
'Some areas of the country have a low water table and if you drain the water from your pool, it could literally pop the pool out of the ground… not a pretty sight! ’ -p. 6 of ‘Pool Care’ pdf.
My pool tech tells me that this could happen with a high water table, does anyone have definitive information?
thank  you.
Hi Porter,
Here is a really good article on Keeping a Pool from Popping out of the Ground. Some of the key points are…
  • This is an extremely rare event
  • Don’t drain the pool if you have had heavy rains
  • Pools at Sea Level or Lake Level are higher risk
  • Drain the water away from pool (i.e. to storm drain)
  • Install a Hydrostatic relief valve in your main drain
  • Work Fast (don’t leave the pool drained for many days)
Thank you, Patrick, for your reply.  It seems like the cause is a high water table.  Possibly the pool care pdf should be amended.
Porter,
Yes you are correct this should read “High Water Table” thanks so much for bringing this to our attention and we will update the Pool Care Guide.
