hello all,
so i have installed a large two flute commercial water slide on an HOA pool. turned out awesome but have a problem. the water pressure that the pool has on the slide water source is too low to push adequate water through nozzles to properly wet the slide. i was wondering first if there is a recommendation for a water booster pump that can connect to the piping. was thinking of adding the booster pump to the pipping that is on the mechanical room. the pool has six very large sand filters and a very impressive system. second the pool was built in 1984 and there are no schematics. how would you recommend that i find the correct pipe water dye? or is there a better way? thank you
