I can get all the prime through my lines and water flows in and out of pool good for a few seconds and then I just see a few air bubbles. I have replaced the pump.
Hi Lburk13,
I have a few questions to help us troubleshoot, could you please answer these…
- Is the pump basket fully filling with water?
- When you put your hand over the jets is the water coming out powerful?
- What type of filter do you have on the pool? Sand, Cartridge or DE?
- What is your pressure reading on your gauge?
Can you post a photo showing the plumbing going in and out of the pump. To post a photo follow the instruction below.
I see no replacement for the knob that turns the valves that go in/out to and from pump. My pipes are all 2 inch diameter, (I guess that’s normal size for home in-ground pools. Where do I find them?
Hello Yurinis - We’d be glad to assist you. If you are looking for a replacement knob/handle for your valve, we’ll need to know the make and model of the valve. Can you post pictures of the valve?
