VS3050
I have a VS-3050 that is about 7 years old. It’s running great, but there’s a small drip coming from the place where the motor mates with the seal plate. The drip is enought to keep the equipment slab wet in that area.
If I replace the shaft seal, is there any other seal I should replace while I am in there?
Is there a “seal kit” I can buy from InyoPools that would cover everything?
Hi CoolRuehle,
Yes the GoKit32 Tune Up Kit would be the correct seal kit for your Pentair VS-3050. It definitely is a smart idea to replace all your o-rings and gaskets when you are replacing your shaft seal.
