Vogue 18' found prima parts
I’m looking for the bottom rails and a new liner for my 18’ vogue prima pool. I only need one or two rails.  is there a similar pool that the bottom rails will work or do you have a part number for replacement?
The bottom rail for an 18’ Vogue Prima pool should be part number LA1254118. If your pool requires 13, that bottom rail will work.
Part number LA1254118 is in stock and ready to ship.
Ok. I will check the number required and call you today.
Do you have a recommendation for a reasonably priced replacement liner?
Good news.  There are 13 top and 13 bottom.  Please post the number to call and place an order asap.  Thanks.
Our phone number is 407-834-2200.
The following link will take you to the 18’ liner page. You’ll have to select the wall size and then the liner type. At that point, you’ll be able to see the available patterns.
https://www.inyopools.com/18-round-liner-wall-sizes.aspx
