hi, attached is two pix. One is my bearing-failed Century HST150(I have new bearings in my cart), but the other pix is of my pump housing. It only has the tag on it. I believe it to be quite old, and I can’t find a match for it for this pump.
I installed new pump (this one) last year, but did not replace shaft gasket, hence a leak and the salt water ate it up. Motor moves water fine, but now loud whine, which has not run very long after this, so I am planning on replacing bearings and gaskets only. Can you decipher the pump house model #?? and which salt kit gasket to use? TIA Tedd p.s. -the pump house has the square see-through top with four swing away screw locks…
And if so, would a PS-4280 fit this motor?
We’d be glad to assist you. Could you post a picture of the complete pump housing?
Here is house pix, however, i took apart my pump, and front bearing is shot…and it looks like pump is toast…
Should I just get a new pump with a salt water shaft seal kit??
I’ve already ordered the bearings(which i wont need for a new motor) and also ordered gokit3salt gasket kit…
I will order a new ust1152 motor today, but can you verify if the gokit3salt is correct for this?
Thanks a bunch!!! Tedd.
Your pump looks more like the WMC AT Series model. However, that pump can use the same seals from the Super Pump. GOKIT3SALT would be the correct kit.
