I just bought a house with a Pentair WhisperFlo WFE-4 1 HP filter pump that I would like to switch to something more efficient. I heard variable speeds are the way to go… but b/c this is a dedicated line (filter only), could I do a lower-power motor?
Hi John, changing your pump motor to variable-speed will certainly help with your utility bill as long as you are able to turn the speed down. Turning it down a few steps can save you 30% or more on the electricity it uses.
The only time variable-speed pool pumps/motors have issues is if you have certain water features like waterfalls or laminar jets. They usually require a good flow to operate properly and look nice.
