For a vaiable speed pump what is the appropriate speed to backwash at? Max of the pump is 3,400
There is not an exact speed to use when backwashing the pool filter. Normally, it’s something where you want to use one of the higher speeds to ensure plenty of water flow when doing this. I would say 2800 rpm is a good place to start and then you can adjust up or down as needed.
