V-Green 2.7 HP Round Flange 56J Variable Speed Motor - ECM27CU need a separate timer?
Does the V-Green 2.7 HP Round Flange 56J Variable Speed Motor - ECM27CU need to be wired to a separate timer or does the interface also work as the timer?
thanks bob
Looking to replace single speed motor,Here are the numbers to the old pump,if you could match me up and give me a price Thanks,  serial 092073M part 7 -164304-24 type CX FR P56J HP 1.5 SF1.30 PH1 HZ60 RPM3450 VOLTS230/115 AMPS SF9.2/18.4 TIME CONT ENCL DP FORM KJM CODE H INSUL B AMB 50
Hi rdtservices,
Thanks for the information! You will require this B128 Pool Motor which we have in stock ready to ship.
