I need to replace my pool filter (American Products Titan RPM 36 sq ft), multiport valve, and 1 1/2 HP pump (American Products UltraFlow). All suction piping is 2" and pressure piping is 1 1/2". Pool holds approx 20,000 gallons with spa/hot tub, 1 main drain, 1 skimmer and 2 water falls. Flow rate is sufficient now to make water falls look good. Suction vacuum uses skimmer suction. Aqualogic control and salt chlorination. Pump runs about 5 hours per day during season (Central Florida).
Looking at Pentair DE 180007 with 2" multiport valve as almost direct replacement. Big question is pump. Is there any advantage to a VS pump? Current pump leaks and must be replaced, but plenty of water for features and cleaning. Would electric savings be significant enough. Recommendations including models.
Thanks.
