I have a GoldLine/Hayward AquaLogic as you have on your website, the 2807-05 and was interested in upgrading to a Variable speed pump.
Wanted to ask if there’s a relatively plug in upgrade I can make myself that you would recommend?
thx, Bryan
thx, Bryan
The AquaLogic and E-Command controls with software revision 2.65 and higher will control the following models via direct (data) communication:
EcoStar # SP3400VSP
EcoStar # SP3400VSPVR
TriStar VS # SP3202VSP
TriStar VS 900 # SP32900VSP
TriStar VS # SP3202VSPND
TriStar VS # SP3200VSPND
SuperPump VS # SP2603VSP
MaxFlo VS model # SP2303VSP
It is also possible for AquaLogic and E-Command controls to control the following models via relay control (not direct, data communications):
TriStar # SP3200VSP
SuperPump VS # SP2602VSP
MaxFlo # SP2302VSP
