I wanted to upgrade my existing pool pump motor from a single speed to a variable speed. I did some research and I believe the ECM16CU is an option that will work. When I chatted online, the rep said I may also need to replace the impeller. Can you confirm the ECM16CU will work in my pump and what other accessories I’ll need (such as the Super II tuneup kit?).
I also have a wifi/timer switch that turns the pump on and off, will this no longer be compatible with the new pump?
Existing setup
- Pump: Hayward SP3000 (RS750CA?)
- Motor: Emerson T55CXCMM-1407 (SP1607Z1BERCA) (.99 THP, .75 FRHP/1.32 SF)
- Filter: Hayward C17502S
New setup
- Motor: ECM16CU
- Seals: GOKIT2
- Impeller? SPX3020CKIT?
