Spa light, stopped working, the label is missing. However, I removed the middle of the three pool lights and there is a label.
This is the spa light
Pool light label.
I cannot find anything on the Pentair Website with any of these numbers:
Series #64000X,
Use with Model #7824xx or 792066,
Label #650040.
Watts 58
Volts 120
Bulb Type: (1) MR8, 35W; (2) MR11, 35W
Fixture Housing, Wet Niche Type. Fresh Water Only.
Do you think the Spa Light and Pool Light are the same?
What do I need to DIY fix/repair/replace the Spa light?
I am considering replacing the Pool Lights while I am at it.
How do I find replacement parts/lights that are compatible?
Note: I am wanting to learn and do this myself after the last pool company removed my spa light, broke 1 of 3 internal light and then put it back in the pool (same gasket) which then proceeded to rust (as you can see by the photo). Said he never saw such a spa light before and after his research said he could not help me and suggested I replace everything with new lights that were “industry standard” that he was familiar with. I have the time and the interest to learn and do this fix myself, correctly.
Thank you for any helpful suggestions and ideas.
