Two Speed Jandy Stealth not click on.
Hello,
My Jandy stealth 2hp 2 speed pump won’t click on high by itself. It’ll buzz and stop and keep trying.
If the pump is on low speed first and I turn on high it’ll click on.
Do I need to replace the motor? If so can I replace the motor with a variable speed?
You might not need to replace the motor. It sounds like it may be a bad capacitor. What is the part number or catalog number of the motor?
Check out the following articles for additional information.
My Pool Pump Runs On Low Speed But Not On High Speed
How To Test a Pool Pump Capacitor
It’s a Century two speed 0-196159-06
The start capacitor is part number 5270-15. The run capacitor is part number 19566235.
Thanks I’ll give that a shot first.
You’re welcome. Thank you for visiting INYOpools.com.
