My top rails have seen better days and would like to replace them. It is an oval Polytec pool about 25 years old. It is about 8-1/2’ by 18’ by 4’ high. Thank you.
Hi, We’d be glad to assist you. For matching above-ground pool parts we will need any or all of the following information. Do you know the make and model of your pool? Pool Size? We will also need a few photos, please supply a close-up photo of your top cap, top rail, and a wide shot showing the pattern of your pool wall. Also if you can pull any part #'s from the top cap, normally this is stamped into the underside of the top cap so you may need to remove the top cap. If you have any documentation from the pool like the owner’s manual then if you could send us the page showing the parts diagram then that is always helpful as well. To add images click the mountain icon, see example below…
I cannot find my bill. I believe the pool is 9 x 17 oval pole pool with two poles on each side, but size had to be adjusted due to location width. I eventually had the poles inverted into the ground rather than have them rising in the air. The longest ledge is approx. 108 inches and the angular ones approx. 27 inches. There are 2 long ledges and 6 smaller ones. Ledge width 6 inches, height 2-1/2 inches. There was no number under the caps since the originals were replaced. Below are pictures of the pool. Thank you for any help you can provide.
Annette
Annette
Forgot to mention the pool was purchased after 1991 from Polytech Mfg which was located in Brooklyn, NY.
We do not have parts for this pool but the following company has the top cap. They may have additional parts for this pool. https://teddybearpools.com/shop/coping-cover-6-white-2-pack-both-sides/
