Hello,
I purchased a Harvest 24’ X 15’ oval pool in 2008 from Branch Brook Pools in Hazlet, NJ. I believe it is a Namco pool. I am trying to fond replacement Top rails. There are 14 rails in total on the pool, I believe the part # is, 211524760 or possibly 1920662. I believe they are 10 1/2 inches wide and they are long. I there any chance you carrynthese replacement parts and if not, would you know where I can purchase them from?
I would realy appreciate your help.
Hi Anthony,
Could you post a few photos of your pool to this thread.
- One which is a wide shot of the pool showing the wall pattern
- A close up shot of the top cap
- A close up shot of the top plate
- A close up shot of the top rail
Also, can you find any part #'s embossed into the pvc top caps and metal top? Many times the part # is on the underside of the top cap. All this information will help us find the correct replacement parts for you.
Hi Anthony,
I heard back from our above ground pool parts expert and he was able to identify your parts. Below are the links to the items you would need.
Harvest is a wall name. Concord is the model. That pool would take the following rails. Qty: 8 1450730 Curved Top Rails
Qty: 2 1450725 Straight Side Top RailsQty: 4 1450731 Corner Top Rails
