Top Rail Rust on above ground pool
I have a 2005 30ft x 15ft x 52in oval pool which has badly rusted top rails from salt water use. There are 16 sections and each when measured directly from end to end (not around the curve) is 55-1/2" long. I have attached photos. The original paperwork suggests the pool is a “Mighty Sun” Everest model. I also need 16 side upper joint brackets which tie-in the rails to the top of the vertical supports. I could not locate any part numbers on the components in question. From my manual, the side upper joint brackets have a P/N: 3172 for a 1" rail. I would like to replace my rusted top rails with resin rails.
Thank you, Dave Cook
Hello Faafgc4 - It looks like you have an Asahi pool. Unfortunately, we do not carry parts for that brand. We recommend trying https://www.asahiparts.com/home.php
Thank you InyoRob.  They had exactly what I needed.  I would likely have spent hours looking so I appreciate you pointing me in the right direction.  How you can determine a particular brand of pool from the pictures amazes me.  There are so many out there that have been sold over the years. Thanks again.
No problem. Thank you for the feedback. We’re glad we could help.
