Our pool is a Galaxy purchased in 2003 from Watson’s. It is 18 x 33 x 52. The caps (part # 27393) look right, but want to check with you first.
thanks, Linda M
thanks, Linda M
Hi LindaM could you send us a photo of your top cap and double check to see if there are any part #'s embossed in it. Also if you could take a wide shot photo showing the wall pattern of the pool that would be most helpful. Please post those photo’s directly to this post.
Thanks so much!
I did also reach out to one of our tech’s and he stated the following…
I found one Galaxy schematic and it was an Aqua Leader model. The top cap was part number 10333370000, it still would probably be best to get photo’s just to make sure.
Also in the photo’s you send can you put a measuring tape in the photo with the top caps, as this will help out quite a bit.
We have a 24’ Patriot Pool, I believe a 2002, Silverado. The walls were replaced under warranty in 2007 due to a manufacturing defect, but the top caps are original and the sun has completely discintegrated the caps. Most are gone because they have literally dissolved. Can you tell me what part number? I contacted you and asked about this part a year or two ago and was offered a discounted price, but we had other financial priorities. Now some of the caps are completely gone making it a safety issue for our nieces that are now using the pool.
Please advise and thank you,
Dave
Hello Dave - Could you post a picture of the top cap?
