Looking for the right part for my above ground pool. Bottom plates for the track and up right.
Hi Sdotson04,
Could you post a few photos of your pool to this thread.
- One which is a wide shot of the pool showing the wall pattern
- A close up shot of the top cap
- A close up shot of the top plate
- A close up shot of the top rail
Also, can you find any part #'s embossed into the pvc top caps and metal top? Many times the part # is on the underside of the top cap. All this information will help us find the correct replacement parts for you.
Hi! Old Litehouse pool 1997. Maybe Esther Williams…not sure. Not opened or used in many, many years. Can the bottom track be replaced that broke? TY. Mary Kay
Hello MaryKay - It looks like an old Haughs Celebrity model. Some of the parts have been discontinued. What is the size of the pool? What is the total number of uprights on the pool?
Hello. The pool is 21’ x 48". My husband built a deck all the way around it, and it is still decent. If we can save the walls and switch out those parts, we hopefully can get a few more years out of it. There are 14 uprights I believe. TY
The original bottom rims were discontinued but they can be replaced with part number 1255621.
Thank you for all the info! MKS
Hi! Do you use 1 rim per upright?
Yes, 1 bottom rim per upright.
