i need a multi port valve top assembly for a sta-rite 18201-0200h. i can’t find this anywhere so if you guys can get me the number i’ll buy it from you immediately
The good news is that there is an alternative to part number 18201-0200H. The replacement is part number 4716-0. The bad news is that it is currently out of stock. You can sign up to be notified when it is available by Clicking Here.
worthless
or maybe if i ask you for a solution you can give me a solution instead of a waiting list???
If the body of the valve is ok, you could replace the top assembly. The part number is 4602-1152. We’d also recommend replacing the spider gasket and cover o-ring if you replace the top assembly. The spider gasket is part number 4600-1148 and the cover o-ring is part number 4600-1151.
If you need to replace the complete valve, the options we have would require that you do the plumbing from the valve to the filter.
A sand filter could use part number 26-253-1220.
A DE filter could use part number 26-253-1215.
