Can you tell me the process to switch a pool from an ION generator to a saltwater system? the pool is above groung 15 x 30 x 54". Also which salt water system would you reccomend?
Hi DDurel,
From my understanding, there is nothing special you need to do to switch from an ion generator to a saltwater system. You would un-install the Ion Generator and install the Salt System. After the salt system is installed then you will follow the instructions that come with the salt system for installation. We also have an article on Converting a Pool to Salt Water which you may find helpful.
