I goofed and ran my pump for about 3 days with the water to the filter shut off! The valves to the pump where open, just the valve to the filter was closed. When I opened the valve to the filter and turned the pump on, water was spraying from the sealplate. When I pulled the sealplate and diffuser off, I noticed the impellar screw was laying dislodged inside the impellar!
Wondering what all I should inspect and/or replace since I have the pump pulled apart to replace the sealplate gasket. Replace the shaft seal too? All gaskets that may have melted? The entire motor?!
