I have what I think I believe is a Hayward Super pump. I’ve bought this house in may. See pics:
The union on top of the pump where the water exits the pump is leaking between the fitting and the pump. I removed the union/fitting, and it looked like it was in good shape. It didn’t look like a typical part I could pick up at Home Depot. I cleaned the thread, put a healthy wrapping of teflon tape on the threads, and put it back in. I tightened it it pretty tight, and it seemed well. It is now leaking again. It is definitely leaking between where the black pump meets the white PVC. Should I try a new fitting? Maybe it is warped? Is there some other way I’m supposed to handle putting this fitting in? It is not a ton of water, but it is definitely leaking.
