Hi
I have a Stra-Rite Max-E-Pro pool pump Model#P6RA6F-206L. I bought pump in 2019 so best guess is 2015 newer.
the motor 1.5HP is shot so want to replace motor and seals. But looking at your seal kit GoKIT79 looks like the seal plate O-ring is wrong for my pump its newer than 2015. So This is what Im looking to buy can you check to see if all is correct. New Century 1.5HP motor USQ1152, Diffuser O=ring 5055-13, Shaft seal 3/4 PS-201 5110-11 and seal plate gasket 2015-current 357099Z. I think current seal plate will be ok but will order 1 just in case.
If items above are correct are all parts in stock if so do they ship out of longwood FL. I live in Palm Beach, Fl.but would like to get this week but second day ship is pretty high cost so maybe free ground if ships from FL.
Thanks for your time John Ludwig cell 561-635-1773
Hi John,
Yes you are correct the seal plate o-ring in the GOKIT79 is not the correct o-ring for the newer models of the Stra-Rite Max-E-Pro pool pumps. My suggestion would be to purchase the GOKIT79 and then also purchase the 357099Z Seal Plate Gasket as I believe this route will be less expensive than purchasing the parts individually. You will also need this USQ1152 Replacement Motor for P6RA6F-206L We put together this Video on How to Replace a Pool Pump Motor which you may find helpful when you tackle this project.
Thanks Patrick
Understood. I did write motor USQ1152 in text.
But is all in stock and does it ship out of Florida. Need this week but perfer not paying 2nd day ship cost.
shipping to Palm Beach Fl.
Hi John,
Yes, all items are in stock shipping from Florida.
I placed order before cutoff to ship today.
john
Hi Patrick
I received the order thursday afternoon all looked good. I installed Thursday night piece of cake. Of course the video on how to change out made the whole process that way. I didnt use the seal plate gasket due to pump was only 1 yr 8 months old before motor winding melted but the rest of the seals I replaced. But I will keep just in case if new motor doesnt hold up long.
But all went well
John.
