Hello,
I have a Sta-Rite pump and filter. The Motor Model# is P2RA5E-181L, Dura Glass 1Hp motor. I’m looking for a replacement motor and Replacement gaskets/seals kit for them. I wasn’t sure of “up rated” or “fully rated” and the kit I found was for pre-1998 models.
Can you please recommend the correct motor and gasket kit, please.
Thank you
Marc
Hi Marclin,
Thanks for the question on your Dura-Glas motor! You will require a USQ1102 Dura-Glas 1 HP Replacement Motor and if your pump is from before 1998 then you will need the Pre 1998 Dura-Glas Tune Up Kit and if your pump is from 1998 and after then you need the 1998 and After Dura-Glas Tune Up Kit
Based on your part # you have an uprated motor and the USQ1102 is the correct motor for you.
