In a chat Eric suggested I email this information and questions….
The sta-rite pump motor for my 5’x 3’ deep round redwood hot tub needs to be replaced. I can not read the tag on the motor. The pump impeller is stamped …C105-92P T.
Please advise the correct motor, slinger, seal insert (cone), shaft seal and lubricant.
Also the inside mouth of the diffuser where the impeller sticks through is a little rough. Will this effect performance?
Thank you in advance!
Louis
Hello Louis - That part number cross-references to a Sta-Rite Dura-Glas model. Does the schematic below look like your pump?
Yes! My pump looks like the schematic.
Please advise the correct motor, slinger, seal insert (cone), shaft seal, lubricant and anything else needed for motor replacement.
Also the inside mouth of the diffuser (stamped C1-216P) where the impeller sticks through is a little rough. Will this effect performance?
Louis
The correct motor would be model USQ1072. The motor will include the slinger. Click Here to View the USQ1072 Motor
The copper insert cone is part number 5056-07A**. Click Here to View the Copper Seal Insert**
The shaft seal is part number 5250-100.Click Here to View the Shaft Seal
The shaft seal lubricant is part number LUBE-PP.Click Here to View the Shaft Seal Lubricant
I would recommend smoothing out the mouth of the diffuser. I’ve used small grit sandpaper in the past.
Thanks!
I have ordered the parts you recomended.
That’s great. Thank you for shopping with INYOpools.com!
Order Number: 1049052
Order Date: 04/13/2020
I entered the number I received in an email from INYO today in UPS tracking and received this message.
Please advise.
Louis Greco
UPS could not locate the shipment details for this tracking number. Details are only available for shipments made within the last 120 days. Please verify your information.
Track
Tracking Numbers
Enter up to 25 tracking numbers, one per line.
Help InvalidPlease provide a tracking number.
I believe the order is just waiting for UPS to scan it into their system. Try again tonight around 8pm and see if the tracking number works. Let me know if it doesn’t.
Just checked UPS at 8:25 am PST this morning (04.17.20).
Same message appears.
Please advise.
Thank you,
Louis
The tracking number in the system was incorrect. The package is out for delivery today.
