Solar Cover
I recently purchased a HP50TA heat pump, but keep losing alot of heat overnight.  Can you recommend a cover for heat retention only.  My pool is 24x18,  10,000 gallon
Thank kindly,
Vincent
Hi Vincent,
If you have an oval above ground pool then I would suggest the 18’ x 34’ Oval Clear 16 MIL Solar Blanket and then cut to the shape of your pool. If you have a rectangular inground pool then I would suggest the 18’ x 36’ Rectangular Clear 16 MIL Solar Blanket and then cut to the shape of your pool. The route of cutting the cover will be much less expensive than purchasing a custom cover to your exact pool dimensions.
