My SHPF2.0 pool pump is making a high pitch sound when it runs. It is 10 years old. I think its the bearings. What part number do I need? and what else do I need with it?
The replacement motor for Jandy pump model SHPF2.0 is part number B2748. Click Here to view the B2748 Motor
We recommend replacing the shaft seal when you replace the motor. There have been two shaft seals used on that model. Check out our guide titled**“How to Select the Shaft Seal for a Jandy Stealth SHPF Pump”.**
