Shaft Seal Replacement
Hello! I have a leak on my hot tub motor and believe I need to replace the seals. The Google machine is not helping out much as I cannot find a parts diagram or any replacement kit specific tonmy motor. I have a Century/AO Smith motor. Model number 177782-03. 60 hz. 115 volts. 11/2.9 Amps. Can anyone direct me to a website that would have the necessary parts? Thank you in advance.
Travis
The 177782-03 part number only tells us that the motor is a 1Hp 2-speed 115v. It does not tell us the make and model of your wet end. Are you able to see any part numbers on the wet end of the pump?
