Shaft Seal for Marathon 5KC39PN2822BX
Good Morning,
I have a Marathon 5KC39PN2822BX pool pump and it is leaking when it is running.  I believe I need a new shaft seal but I can’t seem to find which shaft seal is required.  Also, the pressure is not as high as it should be so I would probably also need to replace the impeller.  Can you please help me find the correct shaft seal and impeller for this pump.
Thanks,
Alejandro
Hello Alejandro - We’d be glad to assist you. Marathon makes the motors but they don’t make the pump. Let us know the make and model of the pump and we can recommend a shaft seal and impeller.
