Looking for a shaft seal for pool pump motor C48l2n134c1
Hello Marino - The number you provided is the motor number. That motor is used on several pumps. We’ll need to know the make and model of the pump in order to recommend the shaft seal. If you are unsure of the model, you can post a picture of the complete pump.
Marino - The picture was not correctly posted. Could you try to post the picture again?
Not able to click the “mountain” from my phone.
UST1152Ser.08609FMAo smith Corp
Marino - UST1152 is the motor. We need a picture of the complete pump.
The shaft seal is for the motor. Don’t ha e a picture at the moment
Marino - The UST1152 is used on several different pumps that use different seal plates. The shaft seal has to fit the seal plate. We’ll need to know the model of the complete pump. Let us know once you have that information.
