I was just wondering which motors would be a cheap but efficient replacement to this motor right here
also wondering where I can buy the impeller that matches the new motor as well. Thank you in advancedHi Watts93kg,
You will need the BN36 3/4 HP Dual Speed Replacement Motor $149 the BN36 is a standard 3/4 HP which is equivalent to your SPL 1 HP in power, you can see that both motors have the same amp draw. If you could post a photo of your complete pump showing the basket as well the plumbing hooks up then we can suggest the proper replacement impeller.
