Seeking 230V 2HP Str-Rite Compatible INYO Motor
Hi
I need a replacement motor and have a 230v 2 hp Str-Rite. Do you have a compatiable motor in your INYO line?
Pentair Sta-Rite P6RA6G-207L Max-E-Pro Standard Efficiency Single Speed Up Rated Pool and Spa Pump, 2 HP, 230-Volt
The single speed replacement motor for the Sta-Rite P6RA6G-207L is model USQ1202. We also recommend replacing the seals when you replace the motor. The seal kit is GOKIT79.
Click Here to View the USQ1202 Pool Pump Motor
Click Here to View the Max-E-Pro Seal Kit
