Sand Filter & Pump
I have an Intex Sand Filter Pump model # SF15110.  It looks as if the motor has a model # of 673M.  It is a 110-120VAC 60Hz.
We have checked the breaker and the GFCI breaker and all has power.  When trying to power up the system the switch on the timer setting and manual setting does not send any power to the motor to turn on.
Is it possible that the switch is bad? If so, is it replaceable?  I called Intex today but they told me that I would have to replace both the motor and filter - that there were no replacement parts for this filtration system.
Hi Selena,
Unfortunately we do carry parts or service the Intex pump and filter systems but many times the Intex parts are not replaceable and you have to replace the entire unit.
