I have a sand filter model number AT3123 aquatools. The valve have numbers 272526. Vlv SD19/22 1.5" high flow.S/N 05183460601552.
having a hard time finding the correct parts. Please help. Thank you.
Hi Shearwave,
This Pentair 262506 Multiport Valve has replaced your 272526 Valve and will work as a replacement for your AT3123 filter.
Thank you!
Thanks Shearwave, let us know how it works out.
Hello again, ok I bought a new spyder gasket but it came with the valve I also had gotten a new spring with it. And compared it to the old one. it stood up about a .25" taller. When I installed it back into the head with the 8-12 bolts that hold it down and put it into position the handle jiggles. I can not remember if it did that before which I want to say no but then again I cleaned a lot of junk from underneath it. But once I unbolt it from the head and pull it back out I then rotate the handle into a couple of positions and it does not jiggle. Bolt it down and jiggles. Ok I had the old spring in it. I then place the new spring in it and it does the same thing. Is this normal?
Hi Shearwave,
I can’t say that is normal, typically the handle would be secure in all positions. How is the valve functioning, are getting any leaking? Is it backwashing okay?
Yes, seems to be backwashing washing as normal. No signs of leaks. Not like it was before. Watched it with a light for a good 5 minutes or more and spot check it every 20 or so.
