Hello,
I have a 2HP variable speed Blue Torrent pool pump that runs it’s schedule from it’s internal timer and not connected to an external pump timer.
I’m looking into converting to a salt water chlorinator. So far, many of the chlorinators require that they are not powered unless the pump is powered. In my set up, there is no way to set my pool pump up in series with a salt water chlorinator.
Is the “low flow” feature not enough to “turn off the power” to the chlorinator when my pump is running at the lower variable speeds…or off completely?
Any suggestions on models will be appreciated.
Right now, I have approximately 15,000-16,000 gallon pool.
Thanks for the help in advance!
JNorth
