Switching over from Chlorine pool to salt water, is there anything that I have to do with the pool pump motor with the conversion? Thank you
I would recommend installing a heavy duty shaft seal. What is the make and model of your pool pump?
AO Smith 1.5 hp item B854 purchased through inyopools
The B854 motor is used on several pumps. We need to know the make and model of the pump side.
sta rite pool pump PAE6F-188L
Sorry actually should be P4E6F-188L
Nothing about Max E Pro
The P4 series is the Dura-Glas II. The heavy-duty shaft seal is part number 35-423-1096.
Thank you
You’re welcome. Thank you for visiting INYOpools.com.
