Salt pool
Hello I have a salt pool and the generating light does not turn on therefore I’m not getting chlorine in my pool. What can be happening?
Hi Johanna,
Do you know which salt system you have, if so then please post the name to this thread. I would first open up the power center and check your fuse. If that is good then many times this indicates a bad PCB board in the power center.
I have a Aqua Rite goldline.
Hi Johanna,
I would suggest taking a look at our Video on How to Replace an AquaRite Fuse if that does not fix the issue then most likely you need to replace your Main AquaRite Circuit Board we also have a Video on How to Replace your AquaRite Board which you may find helpful.
Great thanks the fuse was the issue.
Excellent that was the best case scenario!
