I purchased the 1.65 vairable pool pump motor and V-Green 270 interface. How do I wire my salt generator into this combination?
Hello Perkie1994 - Connection and Programming info are detailed in the VGreen270 user manual on pages 8 and 9. Basically, you are interrupting a leg to turn the SCG on and off and setting a min run speed and max run time. For an SCG system I recommend setting a min run speed of X+ RPM* and a max run time of 24hrs. This way anytime the pump is creating enough flow the system will create chlorine.
*X+ RPM should be determined by running the motor in override to determine the flow rate required by the SCG system. (when the flow light activates you have found your min RPM)
