I have a Pentair Pool and Spa Easy Touch Control System. It is programmed to run from 80 a.m. to 5
0 p.m. during the summer. On the evenings that I shock the pool, I need the pump/filter to run overnight. How do I do this without changing the daily run/auto schedule?
You can manually turn the pump on by pressing the Filter Pump (F) button once. The pump will turn on and run for 12 hours. If you need to turn it off before 12 hours, press the Filter Pump button again.
Thank you. That’s very helpful.
