i have a Hayward Max Flow xl pump. Model # C48031A04
I’m am looking to replace the motor which is a 1hp motor.
Can you send me a list of motor options? Will I also need to replace the shaft seals?
I believe the C48 number should be C48D31A04. That is a single speed 1HP uprated motor. The replacement motor is part number 3260-108.
There is a dual speed option. The model number is SPX2707Z2M.
We would recommend replacing the shaft seal while you are replacing the motor. The shaft seal is part number 3260-105.
You can click on any of the part numbers to view the items on our site.
