I am looking to replace my Hayward ColorLogic Spa light which was installed with new construction 6 years ago.
Is LSCUN11100 my only option?
J
J
Thank you for contacting Inyo. LSCUN11100 is one option. That is the 12v Colorlogic spa light designed to be controlled with the ProLogic. They also have an LSCUS11100 which is designed to work with a standard light switch.
Do you know the part number of your niche?
This is what is currently in my spa. Does this help? My understanding is that the LSCUS11100 is the light I need as my
controller changes the programs by cycling through a series of turning the light on and off. I could certainly be wrong!
The picture included shows the outside housing of the light fixture. It’s probably a ColorLogic 4.0 Spa LED model series # SP0535xxxx. The niche isn’t pictured nor stated. The niches that we recommend for that light are: SP0601U (for concrete), SP0610C (for concrete), and SP0608U (for vinyl/fiberglass). These are the same niches that we recommend for the Universal ColorLogic Spa Lights, Universal Crystal Logic Spa Lights, and the AstroLite II Spa Lights.
The fixture is 7 years old and my understanding is that it is therefore a ColorLogic 2.5 as we previously discussed.
The only question is whether I need the networked or switched model.
J
You can use either one.
Great thanks!
J
You’re welcome. Thank you for shopping with Inyo!
