Replacing a Polaris 3/4 HP Booster Pump (PB4-60)
Hi,I have an old Polaris 3/4 Booster Pump (PB4-60) that I am trying to replace. I see on your website that you sell the full pump, to avoid replumbing my entire system i would like to only replace the motor and not the impeller and other attachments. As such I have several questions on the matter. 1. Is it possible to only buy a motor replacement and not the full pump from your website?2. When replacing the motor are their any common parts that are usually replaced in this process? (i.e. impeller, o-ring seals, etc.)3. If i buy a new motor will it be backwards compatible with the old pump mounting system?  Any help would be greatly appreciated, Thank you.
  1. Yes, the motor can be replaced on an older Polaris booster pump. The replacement motor is model B625.
  2. The common parts that need to be replaced are the seals and gaskets. We have a kit for booster pumps manufactured before 2011. The part number is GOKIT71.
  3. The motor will mount up to your existing housing.
