Replacing 1hp sp1607z1m with A.O. Smith ECM16CU 1.65HP 230V Variable Speed Pool Motor Pump Ro… What parts will I need to replace, with part numbers please?
What is the model name of your Hayward Pump? Is it the Super Pump, Super II, or Max-Flo pump?
Super pump.
You’ll want to replace the seals when you replace the motor. Below are links to the Hayward Super Pump seal kits.
Click Here to View the Standard Super Pump Seal Kit
Click Here to View the Super Pump Seal Kit for Saltwater Pools
Do I need to replace the impeller?
You do not need to replace the impeller.
Okay. Thank you.
You’re welcome!
